Page Peel Banner not working on joomla 3.6.3
- Posted by renoo99 (1) Offline
I have upgraded my Joomla-Site from 3.6.2 to 3.6.3 and now I get the following message:
500 - You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ')' at line 3 SQL=UPDATE #__banners SET impmade = (impmade + 1) WHERE id IN ()
If I disable the PagePeel module, then everything is fine and the site works ok.
Maybe you can fix it?
Regards, René
10 years 2 weeks ago #1
by renoo99
Regards, René
Hi I'm unable to replicate the issue and looks like it's more related to joomla banner component where publishing time does not honor timezone. See this github.com/joomla/joomla-cms/issues/11969
To make it sure, can you try to publish a (default) joomla banner module and check whether the same issue is happening or not?
10 years 2 weeks ago #2
- Posted by Kurt Manos (6) Offline
I followed directions, published the banner with no expiration date, and it showed fine. I then changed the expiration date to last week, and it no longer displayed. I received no error. I experimented more with other banners, but received no errors.
I only receive the error if I publish the pagepeel module. As I said, it's been working beautifully since I first started using it, but broke as soon as I applied the latest Joomla update.
10 years 2 weeks ago #3
by Kurt Manos
@kurtmanos
Do you have any development server with the the same issue so I can make some test on it?
Or Is it possible for you to provide temporary access to your website so I can make some tests? If it's possible you can enter the details using the "You Site Details" tab below. Only support team who are able to see that.
10 years 2 weeks ago #4
In the interest of resolving this issue, I tried it on one of our other company sites, with the exact same result.
Unfortunately, I can't grant you access to our corporate sites, but I will speak to our CEO to see if I can't publish a backup on a subdomain for you to access.
10 years 2 weeks ago #5
by Kurt Manos
@kurtmagnos I'm fully understand with the situation. No problem with that.
Anyway, can you try to open file ../modules/mod_responsivebannerslider/helper.php with your favorite php editor find this code below at line 68 :
try to change that to :
then let me know the result
10 years 2 weeks ago #6
$model->impress();try to change that to :
if ($banners)
$model->impress();
}then let me know the result
