Error in Responsive Banner Slider
- Posted by Armin Brettschneider (10) Offline
I have bought it yet, but if I enable it there appears an Error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 3 SQL=UPDATE #__banners SET impmade = (impmade + 1) WHERE id IN ()
10 years 2 weeks ago #1
Hi, we have updated the module can you try to reinstall it again?
10 years 2 weeks ago #2
The Error is away, but I can´t diplay any Banner - there is an empty Modul ?!
10 years 2 weeks ago #3
Strange,
I have doubled-checked it again and it's working properly. Could you tell me what parameters do you have in the module backend?
Also have you already read the documentation file about how to add a banner?
10 years 2 weeks ago #4
I´ve read it. I can give you access to the backend. I choose a category (The normal Banner-Menu diplay it) , count=11, serc by tags=no, Randomise=Sticky
10 years 2 weeks ago #5
