Related Items Extended Not Working
Error in plugin's page: Warning: Invalid argument supplied for foreach() in /web/htdocs/www.diar***4.it/home/libraries/joomla/database/driver.php on line 1490
my joomla web site: www.diario1984.it/
screen: i.imgsafe.org/cd2d2c06a2.jpg
10 years 3 hours ago #1 by Gabriele
HI, It's strange. I think it's related to your joomla installation, not with related item extended module only. Because other plugins seem to have the same problem. Please see this screenshot :
https://www.dropbox.com/s/2i1bpijhppms0f3/4fl2i.jpg?raw=1
It's the core joomla plugin and it has the same problem.
Maybe you'd consider to update your joomla version to the latest version?
9 years 11 months ago #2 by TemplatePlazza
Update Error...
9 years 11 months ago #3 by Gabriele
Hi gabriel, I'm not sure why that could be happened but you can try this : www.google.com/search?q=the+archive+file...issing+joomla+update
Anyway please don't forget to make a BACKUP before upgrading and make sure all of you extensions are compatible with the latest joomla version.
Also, please be aware that the error message you mentioned in this thread (Error in plugin's page: Warning: Invalid argument supplied for foreach() in /web/htdocs/www.dia***84.it/h**e/libraries/joomla/database/driver.php on line 1490) is related to your joomla installation, not related to the related item extended module. So it is likely the module still work properly even if you are not updating your joomla installation. Have you tried it?
9 years 11 months ago #4 by TemplatePlazza
