Language - LatestNews+
I'm using the LatestNews+ module on a swedish site and I wish to know in what file or where i can change the text "More in". I wish to translate it into swedish.
9 years 11 months ago #1 by Anders
Hi, copy these files :
../language/en-GB/en-GB.mod_latestnewsplusdate.ini
../language/en-GB/en-GB.mod_latestnewsplusdate.sys.ini
to
../language/sv-SE/sv-SE.mod_latestnewsplusdate.ini
../language/sv-SE/sv-SE.mod_latestnewsplusdate.sys.ini
then edit the file ../language/sv-SE/sv-SE.mod_latestnewsplusdate.ini with your favorite php editor. At lines 93 you will see this code
MOD_LATESTNEWSPLUSDATE_MORE_IN="More in"
simply translate it to your languange by changing the "More In" text. So it would become like this :
MOD_LATESTNEWSPLUSDATE_MORE_IN="Mer i"
9 years 11 months ago #2 by TemplatePlazza
Great! - Thank you for a fast reply and solution!
9 years 11 months ago #3 by Anders
No problem at all ;) Glad it solved the problem
9 years 11 months ago #4 by TemplatePlazza
