Can Responsive Banner Slider have two different sizes modules in same page?
  • Posted by JOSUE CANALES MEZA (4) Offline
I wanto to purchase Responsive Banner Slider but need to know if it can handle two or more different modules (in different positions and sizes) for example: One in Square Position and other in Leaderboard position.
It's kinda urgent for me to know.
9 years 11 months ago #1 by JOSUE CANALES MEZA
Hi, it would depend on what animation effect you choose. Some animation effects have a css and javascript conflicts with particular effects. So if you let me know what type of animation you'd like to use, I can try it at my end and let you know the result.
9 years 11 months ago #2 by TemplatePlazza
Hi, thank you very much for your reply. Actually I don't care about the animation effect all I need is to have more than 2 modules of different sizes in the same site: Square + Leaderboard or Square + Leaderboard + Skycraper if possible. If it can be done I'd buy the module right away
9 years 11 months ago #3 by JOSUE CANALES MEZA
The banner itself will fill its container (for the responsive purpose), so as long as the module positions having different sizes, it will follow it. I can't say this 100% possible or not but you can try it if you want to. If it doesn't work as you want to, then just let us know why it doesn't work for you. If the reason makes sense then we will issue you a refund.
9 years 11 months ago #4 by TemplatePlazza
