Can I insert related item extended module into article?
- Posted by Bob Coyne (2) Offline
I am trying to link a menu item to a collection of articles, like Joomla's standard category articles. So it would have rows and columns and display an intro image and title.
If I link a menu item using Joomla's tag feature it won't work. If I use your related items extended component, would this allow me to link a menu item or place the module within an article?
Hope you can help.
9 years 11 months ago #1
by Bob Coyne
Hope you can help.
Just to follow that up. I want my page to look like this, soundblab.com/reviews/album-reviews but not to show from a category, only to show articles that are all tagged the same.
9 years 11 months ago #2
by Bob Coyne
Hi, basically you can do that by call the module inside the article. But please note that Related Item Extended is a module, not component so it has limitations. For example, it won't have paginations like you have on the soundblab.com/reviews/album-reviews
9 years 11 months ago #3
