banner slider breaks site
mod_responsivebannerslider does not work with the newest Joomla update. Please advise.
9 years 10 months ago #1 by Jennifer Joyce
Strange. it works properly on the demo site demo.templateplazza.com/joomla/index.php...onsive-banner-slider (it's running J 3.6.5)
Could you point me to the page you have installed the module?
9 years 10 months ago #2 by TemplatePlazza
it is on all pages in the header. I had to disable it so my site would work.
9 years 10 months ago #3 by Jennifer Joyce
I was getting the following message:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 3 SQL=UPDATE #__banners SET impmade = (impmade + 1) WHERE id IN ()
9 years 10 months ago #4 by Jennifer Joyce
Hi jenjoyce, What responsive banner slider version do you use? I think this issue is already fixed in the latest 3.1.1 version
9 years 10 months ago #5 by TemplatePlazza
I am using Version 2.2.5. Where do I get the update?
9 years 10 months ago #6 by Jennifer Joyce
