Latesnews + Modul
- Posted by Habib Nofel (4) Offline
Dear Template Plaza,
I have installed the module latest news +, but it looks like viewing hours are not the same (depending 5 hours) with clock local I am (Server Time Zone: ASIA / Jakarta), whereas the other modules is appropriate to follow the serving hours at Server Time Zone that already exist. Please support me to solve this problem. Thank you for your attention.
Best Regards,
Nofel
9 years 10 months ago #1
by Habib Nofel
Best Regards,
Nofel
Hi, I have checked your website, and seems everything goes fine. Please have alook on this video www.dropbox.com/s/2dxizk6jdnxdrkj/lnddtime.mp4?raw=1 Am I missing something?
9 years 10 months ago #3
PROBLEM SOLVED.
I changed this file:
/libraries/joomla/utilities/date.php
Line 302:
// If the returned time should not be local use GMT.
if ($local == false)
parent::setTimezone(self::$gmt);
I changed with this:
if ($local == true)
9 years 10 months ago #4
by Habib Nofel
Line 302:
if ($local == true)
Don't forget visit my website: www.republikmurah.com
Hi, I wouldn't recommend you to hack the core file, as it will be overriden by new Joomla update. Have you tried to change the server time zone from the joomla backend? https://www.dropbox.com/s/zh4jlgkem5fxn8x/n8wu1.jpg?raw=1
9 years 10 months ago #5
Helo,
yes I already change it (server time zone), but it doesn't work..
but now the problem was solved because I changed this file in Line 302:
with this:
if ($local == true)
BEFORE I CHANGE :
Line 302:
AFTER :
if ($local == true)
Now the problem SOLVED.
Thank you for your support.
Best Regards,
Habib Nofel
9 years 10 months ago #6
by Habib Nofel
with this:
if ($local == true)
BEFORE I CHANGE :
Line 302:
AFTER :
if ($local == true)
Best Regards,
Habib Nofel
