mini k2 and lof k2 shlideshow problem
  • Posted by Antonino Lupieri (1) Offline
when I use mini k2 module default template with lof k2 slideshow, the last one does not work properly.
the slideshow goes in load loop; nothing is show, just a rolling wait gif.
Thanks a lot for our support.
14 years 1 week ago #1 by Antonino Lupieri
Hi Antonino,
Is there any option inside K2 slideshow parameter to disable loading jQuery library? It may be caused by jQuery conflict between them. IF disabling it from one of them still not work (depends on which jQuery lib loaded first from where) then there also might be caused by the script conflict like variable etc.
14 years 6 days ago #2 by erwinschro
