Responsive Banner Slider
I bought this module and the pdf attached to it so so POOR.....
where can i get more detailed documentation of how to create banners like the demo.
10x.
9 years 9 months ago #1 by doron
Hi doronm, Sorry if you found it difficult use the documentation file. But indeed there's no additional step to use the module. You just need to create banners from joomla banner component then let the module display them with chosen effect. Could you tell me what effect type you'd like to use?
9 years 9 months ago #2 by TemplatePlazza
I don't quite understand where in the banner component I need to put the images/text/read more.
can you please send me a sample code of a banner ?
i.e the demo page:
demo.templateplazza.com/joomla/index.php...onsive-banner-slider
thank you in advance,
Doron
9 years 9 months ago #3 by doron
Hi doronm,
You can find it under the component menu. Please see this image :
https://www.dropbox.com/s/9xogj3wdkqi3z1y/banner.gif?raw=1
You can save it directly from the demo page right? Just do right-click over the image
https://www.dropbox.com/s/n9nlf8540ere3j1/sample-imgs.gif?raw=1
9 years 9 months ago #4 by TemplatePlazza
Sorry, I don't want sample code of animated gif!!!! whats the banner here ?!?!?
I want a sample code of a text with 2 images that makes a banner and see how the parts are animated with you're module.
what did I payed for if you're sample is just animated gif.....
10X
9 years 9 months ago #5 by doron
Hi doronm, Sorry I don't understand what sample code you mean. There's no code needed for the animation. All of animations effect are automatically generated depends on what slide settings you choose from the module backend.
Regarding the banner sample for demo.templateplazza.com/joomla/index.php...onsive-banner-slider , as I said before, you just need to do right click over the image in the demo site then choose 'Save image as' to save the image to your computer (I have attached the images below to make it easy for you). Then go to your administrator page, make a banner by clicking on
the Components > Banners > Banners menu
https://www.dropbox.com/s/7jork6pxvud04ix/4e9ht.jpg?raw=1
then click the button 'New'
Fill all the required fields : title, image, alternative text and click url.
https://www.dropbox.com/s/uuayvpjglgoth90/dalb5.jpg?raw=1.
Repeat the steps for next banners.
Then go to module manager to publish the module (don't forget to enter correct settings such as banner category, slide settings etc).
The module will automatically generate the animation effect depends on what slider type you choose.
9 years 9 months ago #6 by TemplatePlazza
