Carousel Banner not working with Joomla 3.6.5
  • Posted by Kai Metsävainio (3) Offline
I found out that Carousel Banner broke front end site when trying log in in to frontend administration. It gives same error like Responsive Banner Slider before:
500
YOU HAVE AN ERROR IN YOUR SQL SYNTAX; CHECK THE MANUAL THAT CORRESPONDS TO YOUR MARIADB SERVER VERSION FOR THE RIGHT SYNTAX TO USE NEAR ')' AT LINE 3 SQL=UPDATE #__BANNERS SET IMPMADE = (IMPMADE + 1) WHERE ID IN ()
Public site works fine.
Best regards,
Kai
9 years 9 months ago #1 by Kai Metsävainio
Done, it has been fixed. Please redownload and reinstall it
9 years 9 months ago #2 by TemplatePlazza
Sorry, but still the same problem. Tried first to reinstall extension, no changes. Tried to uninstall it and clean install. Now error message comes even in public site so I have to unpublish module.
9 years 9 months ago #3 by Kai Metsävainio
Sorry, It has been fixed. You can try it again
9 years 9 months ago #4 by TemplatePlazza
Thank you, now it's working fine!
9 years 9 months ago #5 by Kai Metsävainio
