The {loadposition} or {loadmodule} tag to present inside article so that it is above comments is not working
It just hangs and I get a Gateway Timeout Error: The gateway did not receive a timely response from the upstream server or application.
9 years 8 months ago #1 by Patrick Roden
Hi, could you tell me what extension you are talking about?
9 years 8 months ago #2 by TemplatePlazza
This is for mini frontpage, by the way it works on non hidden menu items and their children, but the menu that is hidden it does the hang.
9 years 8 months ago #3 by Patrick Roden
Hmm really strange. It should have no relation to menu. Maybe there's any other plugin enabled on that page with hidden menu? Also, can you try to switch the template into the default one on that page to see if this related to template or something else.
9 years 8 months ago #4 by TemplatePlazza
It happens when the article and menu are for the same category
9 years 8 months ago #5 by Patrick Roden
If I remove all content in page it still happens
9 years 8 months ago #6 by Patrick Roden
