Mini frontpage not visible
I set up minifrontpage but there is something strange. After saving it the articles are not visible anymore...
What could be the reason for that? I included my details in the form below.
Best,
9 years 8 months ago #1 by stefan
Hi, I entered your website but can't spot what module is published on that page (you have several mini fp modules published). I have tried to switch the error reporting to devlopment level to see any error may be generated but there's no error either on that page. I suggest you to double check settings on the module such as category etc.
9 years 8 months ago #2 by TemplatePlazza
Hi ,
I checked everything but can not find it ... the error is still there..
In the extra site details I included the pages what it is about.
9 years 8 months ago #3 by stefan
Hi, I have entered your website and increased the Period of Novelty to 3600, it should be working properly now. Please check
9 years 8 months ago #4 by TemplatePlazza
Thanks for your answer but it still does not work.
It does not show the images... When I first used it and before it dissapeared there were images shown. The images are still in the articles and the settings are correct.
And also there are more then two articles.... only two names without images are shown.
So the module is still not reacting as it should be.
Any idea?
9 years 8 months ago #5 by stefan
Hmm strange,
anyway, can you try to rename these file names into all lowercase and try again :
smcp.keizerkarelwebdesign.de/images/mede...megen/Sander-150.jpg
smcp.keizerkarelwebdesign.de/images/mede...ijmegen/Mike-150.jpg
9 years 8 months ago #6 by TemplatePlazza
