Changed Look and feel for Related items
- Posted by Developer (12) Offline
Step 1) I have installed Related Items Extended module. Please check - www.screencast.com/t/JAbaqDImw
Step 2) I have changed “look and feel” for Related items.
And created similar for that – www.screencast.com/t/8jvQqLA4Pvu
Please explain me which file are changes?
Our site Url - www.guru99.com/java-platform.html
9 years 8 months ago #1
by Developer
Hi, unfortunately the module supported max 3 columns. To make it support 4 column you need to make change to both of php and css file. If you're willing to do that, you can do that by doing a template override. Copy the file ../modules/mod_relateditems_xtd/tmpl/default.php to ../templates/your_template_name/html/mod_relateditems_xtd/default.php and edit it using your php editor.
9 years 8 months ago #2
How can I add parameters like “on click event” in Image. For Ex. –
<a href="/java-tutorial.html" onclick="ga('send', 'event', 'Related_articles', ‘articles name', 'articles name');><img src="/java" /></a>
to all links generated via your module so that I can do tracking in google analytics?
Please help me.
9 years 8 months ago #3
by Developer
Please help me.
HI, isn't it already answered on this post : www.templateplazza.com/forum/articles-ha...-display#reply-10260?
9 years 8 months ago #4
For this ticket number #10260 is reply from “onclick event” for add in the hyperlink. Not in <Image> Tag.
my Requirement is
How can I add parameters like “on click event” for <Image> Tag. - www.screencast.com/t/P4NM9CJz
Our site url is - www.guru99.com/assertions-in-jmeter.html
9 years 8 months ago #5
by Developer
my Requirement is
Any Update?
How to remove hyperlink for category in Related articles. - www.screencast.com/t/Zw1XAMM2p
9 years 8 months ago #6
by Developer
Any Update?
