Carousel Banner Not Showing
- Posted by Julian Haines (7) Offline
I have installed the latedt carousel banner in joomla 3.6.5 and setup but the module is not displaying anything and no errors, i have tried in many positions and configurations with no luck.
thanks
9 years 8 months ago #1
by Julian Haines
thanks
Hi, are you using the latest version? Could you let me know the URL of your site so I can take a look?
9 years 8 months ago #2
hi,
Its https:\\www.rowjoo.co.uk it should be showing on the main page in the center but nothing not even the module title.
Julian
9 years 8 months ago #3
by Julian Haines
Julian
From the website I found that no banner is loaded. Are you sure you have already add the banner? What settings do you have on the module parameters?
9 years 8 months ago #4
Yes I have loaded in the footer at the moment its enabled and pointing to some banners see screen grab,
9 years 8 months ago #5
by Julian Haines
