Responsive Banner Slider
- Posted by Julian Haines (7) Offline
Web: www.rowjoo.co.uk/
I have just installed and setup two example banners the same size 728 x 90 but there is some odd size issues going on and looks odd why is this happening? I can see a option to set the size.
Its at the bottom in the footer
Julian
9 years 8 months ago #1
by Julian Haines
Julian
Hi, How did you add the images?
Are they external images? I see that there's a looping the console calling the external image. Please see this
www.dropbox.com/s/wvw2c0k59uvo6ni/rbsrsb.mp4?raw=1
9 years 8 months ago #2
One was internal and the other external, I have made both internal images and still the same red box.
I have also moved into the banner box to make certain is was not the position but still happening, I am using the latest version of joomla.
Julian
9 years 8 months ago #3
by Julian Haines
Julian
Can you try to disable jch optimize plugin and see if the issue persists?
9 years 8 months ago #4
I disabled but still the same, if i give you admin access can you take a look?
regards
julian
9 years 8 months ago #5
by Julian Haines
regards
julian
I feel stupid it was to do with my HTML code i have changed and now working, thanks for your help.
julian
9 years 8 months ago #6
by Julian Haines
julian
