Bounce activated but nothing is showing
I tried to set up the extension and activated it for testing purpose.
www.talking-business.de
but the modal is not poping up at all.
Any hints?
9 years 8 months ago #1 by OS
Hi I don't see th module is published on the page you mentioned. Are you sure you have published it on the correct module position?
9 years 8 months ago #2 by TemplatePlazza
Maybe this is the first errror, does it need to be published in a special position?
I put it into the footer position and enabled show title so you can see "jbounce" below. It's active.
9 years 8 months ago #3 by OS
ok, sorry, seems to be working now.
Had to play a little bit around with the z-index.
9 years 8 months ago #4 by OS
ok glad to know you've managed to solve it
9 years 8 months ago #5 by TemplatePlazza
