Popuplogin module shows not secure
I am using the nice poplogin module. When I placed it on my website and click on the tab plugin, the login form shows but I cannot use the form because I got the warning that the site is now not secure to fill in your loginname and password.
Can you help me solve this problem, because I would like to use your module very much.
9 years 8 months ago #1 by mvD
Hi, try to enable the Encrypt Login Form setting from the module backend
9 years 8 months ago #2 by TemplatePlazza
Unfortunately this didn't help. Maybe you can see yourself when you go to the website and click on the login button.
I hope you have another solution to get it work!
Thanks in advance!
9 years 8 months ago #3 by mvD
I forgot to get the website name in my message www.testsite.joomla-designers.nl
9 years 8 months ago #4 by mvD
Hi, the problem is not about secure or not. It's something related to css.
Try to add this code to your css file :
#fade {
z-index:3!important}
9 years 8 months ago #5 by TemplatePlazza
You mean the template css file?
9 years 8 months ago #6 by mvD
