Problem with Thumbnail related items extended
- Posted by Bruno (6) Offline
Hello, first of all I apologize for my english because I use google translator.
Then I downloaded the Related Items Extended and my problem is that despite my settings, it does not display the Thumbnail. This is the main reason I bought the extension.
I do not understand then I allow myself to ask for your help.
Thank you
9 years 5 months ago #1
by Bruno
Thank you
Hi, Could you let me know the URL of your site so I can take a look?
9 years 5 months ago #2
- Posted by Ivan (5) Offline
Bebo7500. Também comprei esta extensão há pouco e estava a ter esse problema, mas pense que consegui resolver.
No meu caso, não apareciam os thumbnails enquanto no parâmetro "Introtext Item" das opções do module constava o valor "2". Aumentei o valor e já passei a ter thumbnails. Talvez isto também funcione para ti.
Translation of the above:
Bebo7500. I've also bought this extension a short while ago and was having that problem, but I think I got around it.
In my case, the thumbnails wouldn't appear while the parameter "Introtext Item" in the Module Options had the value "2". I increased this value and the thumbnails started appearing. Hope it works for you too.
Cheers!
- Ivan
9 years 5 months ago #4
by Ivan
Cheers!
- Ivan
Obrigado pronet, mas comigo nao funciona, ja tentei aumentar esse valors mas nao teve efeito nenhum. Porque sera que o administrador nao me respondeu ? Tarda em responder ?
The idea proposed above did not work. I am still waiting for a solution to my problem.
Best Regards Bebo
Hi bebo, could you point me to an url with the module published?
I've tried to browse your website and unable to spot the module
9 years 5 months ago #6
