Related Items Extended Blank Square in Module Position when no articles found.
I have an issue with this extension, which hopefully you may have some solution.
The extension is working great inside the articles.
But, there's one page, the category page (which is accesible by main site menu), in which the Related Items Extended malfunction.
Instead of not showing anything, since there are no "articles" with same tags for that particular page, it shows a blank rectangle in the same position it usually appears for the "Related Articles".
Any ideas on how could I stop this behavior?
Thanks!
9 years 5 months ago #1 by Ivan
Hello, I've fixed this issue.
The problem wasn't the Related Items Extended extension.
The problem was with my own template.
If anyone has this problem, you can look around for a third-part extension for controlling modules, which allow the option "hide if empty".
Thanks again!
9 years 5 months ago #2 by Ivan
Ok thanks for the confirmation ;)
9 years 5 months ago #3 by TemplatePlazza
