Carousel banner makes more rows
- Posted by generalst (2) Offline
I'm using carousel Banner on a website from my sportsclub to show sponsorship logo's.
They all need to be in one row and could be shown in randomise following.
But when I change the 'Count' from 4 to more it makes 2 or more rows.
Now it's only showing 4 banners.
How do I set it to show all banners in 1 row? Have the following settings:
The site is www.fccbarendrecht.nl/
Found on this forum something with CSS?
Thanks in advance.
Regards, Stefan
9 years 5 months ago #1
by generalst
Thanks in advance.
Regards, Stefan
Can you try to switch your template to the default one (protostar) to check whether the problem related to the template or something else?
9 years 5 months ago #2
Hi admin,
Thanks for your response. It seems to be a problem with the template because the Protostar doens't make more rows.
You know where I need to look or change something to make it work, like in the other template?
Have a small example attached.
Regards, Stefan
9 years 4 months ago #3
by generalst
Regards, Stefan
- Posted by Adapta (1) Offline
I have solved a problema similitar to this just changing the jcarousel-item class to "width: auto !important;".
7 years 9 months ago #4
by Adapta
Just to make sure, so, is your problem already solved now?I have solved a problema similitar to this just changing the jcarousel-item class to "width: auto !important;".
