modal click button not showing
- Posted by Jana (3) Offline
Ive added the <div class="mimopen-button">Open Modal</div> at the bottom of this article but the button is not showing, only see the text 'Open Modal'.
elingo.co.za/products/process-automation
Your document doesn't specify if the module needs position when you select the custom 'button click' feature, but i tried with and without, it doesn't work.
Would appreciate if you can assist.
9 years 3 months ago #1
by Jana
Hi, sorry for delay in responding. Anyway have you already read the documentation? basically you just need to publish the module in any position, then choose what module position inside the modal to load from the module parameter.
9 years 3 months ago #2
But i dont want to publish it in a module. I would like to add it in an article. If I add it to odule, i just get a blank page.
9 years 3 months ago #3
by Jana
To place the module inside article you can use {loadposition syntax to call module position. Have you tried it?
9 years 3 months ago #4
