Problem with Responsive Slider
Dear Team,
I have bought a responsive slider but seems I cannot configure it properly.
I was aiming at having a simple slider, with basic transition effect and hyperlink. Something like on my main site wczasywazji.pl or
Responsive Banner Slider Nivo Default demo template.
However, no matter hard I try, I cannot rid of this caption. I would like to display just pure image, without any additional information on the slide. Here is what I managed to get: \
wczasywazji.pl/hidden.html
Would really appreciate your help.
Kindest regards,
Slawek
9 years 2 months ago #1 by Slawek
Hi, Have you tried to change the theme setting to "Light" ?
https://www.dropbox.com/s/aeo0bf2ze11j80f/gpnb9.jpg?raw=1
9 years 2 months ago #2 by TemplatePlazza
Yes, I have such settings:
And result is like this
image.prntscr.com/image/zOiXQMfkTuCriMPhDD-Xmw.png
9 years 2 months ago #3 by Slawek
Strange, by setting 'Show Caption' to No, should hide the text. I have tried to reinstall and test in my localhost and it's working fine.
9 years 2 months ago #4 by TemplatePlazza
Anyway if it's still doesn't work with 'Show Caption = 0' you can try to hide it via css. Try to add this code to your css file :
#responsive-banner-slider .nivo-caption {display:none!important;}
9 years 2 months ago #5 by TemplatePlazza
Added this to custom.css and worked perfectly!
Thank you!
9 years 2 months ago #6 by Slawek
