TemplatePlazza multilanguage. How to change Days, minutes in other language ?
Hello!
I am trying to install templateplazza in another language!
Someone can help to change "Time left to buy" and "Days", "Hours", "Minutes", "Seconds" in another language?
Where I can change it ? In what files ? Because I tryied to do this in language files, but on site doesn't appeear nothing !!!
13 years 10 months ago #1 by Iulian
Hi lulianfill,
Thank you for your recent puchase.
It can be found in this file : <root>/language/en-GB/en-GB.tpl_deals_plazza.ini
There are lines there
TPL_DEALPLAZZA_FEATURED = "Featured"
TPL_DEALPLAZZA_BUY ="Buy"
TPL_DEALPLAZZA_EXPIRED ="Expired"
simply change that into what you want.
Hope this helps
13 years 10 months ago #2 by andy
Thank you for answer...
But where we can translate these words : "Days", "Hours","Minutes" & "Seconds" ???
And Login and Sign Up form in the top of the site ???
13 years 10 months ago #3 by Iulian
Hello iulianfill,
Did you try it?
13 years 10 months ago #4 by ronysyz
This part can be translate by adding small pieces of code that is available in here : keith-wood.name/countdown.html
Can you tell me what language you're willing to use so we can suggest you how to add the code?
13 years 10 months ago #5 by andy
I want to use Romanian language.
On our site has dissapeared "Days", "Hours","Minutes" & "Seconds" ??? I don't understand why ?
And the rating stars doesn't work !
Can you help me to solve this problem ???
13 years 10 months ago #6 by Iulian
