I set autohide for Module In Modal and it changes the alpha background but the modal is still on
  • Posted by Andres Gutierrez (5) Offline
Hi, I set autohide for Module In Modal and it changes the alpha background but the modal is still on. i need the modal disappears after 5 seconds. thank you
9 years 3 weeks ago #1 by Andres Gutierrez
Hmm strange, could you try to switch the template to the default one (protostar) and let see if the problem persists?
I'd like to know whether this is something related to template or something else.
9 years 3 weeks ago #2 by TemplatePlazza
I uninstalled that template... how could it be fixed?
9 years 3 weeks ago #3 by Andres Gutierrez
Hi. I tested your module in a new joomla installation and it worked fine. How can i fix it in my website?
9 years 2 weeks ago #4 by Andres Gutierrez
Is the new joomla installation using the default template or using your previous template?
9 years 2 weeks ago #5 by TemplatePlazza
I used the default one, now i switched it to the yootheme pro (the same one cause of this post) and is still working. I activated a slider using wdgetkit, like in the original site, and your module is still working... what else could be wrong?
9 years 2 weeks ago #6 by Andres Gutierrez
