Slider opens directly without finishing reading the entire article
- Posted by Fernando Bautista (8) Offline
Good morning.
When you open any article, the slider of related articles immediately appears and it is assumed that this should appear as soon as you finish reading the article at the end
I need a solution to this problem, thank you.
8 years 10 months ago #1
Could you let me know the URL of your site so I can take a look?
8 years 10 months ago #2
Can you try to switch the template to the default one to see whether this is a template problem or something else?
8 years 10 months ago #4
I only have a default template and layout for the whole website which is made with Gantry5 and Joomla 3.8.3
It was working fine, I do not know if it's because of the new Joomla update
I am also working under PHP 7.0.26
8 years 10 months ago #5
From what I see the problem is because the trigger to open the slideout is called twice on your website. One on the top area (search module) and one at the end of article (the correct place). I think the top search module is set to call plugin inside the module.
Can you try to disable that module temporarily to see whether it's the reason of the issue or someting else?
Please see this image
https://www.dropbox.com/s%2Fx05ig2n6mm8ml6p%2Fnn7wb.jpg?raw=1
8 years 10 months ago #6
