When uninstalling K2 component from the quickstart my site crashed
- Posted by Christoffer Lindblom (14) Offline
Please assist. I get now the following error message:
8 years 7 months ago #1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ORDER BY content.created DESC' at line 25
Hi Christoffer, to fully uninstall k2 you need to uninstall all k2 related extension (component. plugin and modules). You can find any related k2 extension by filtering the Manage Extension page from your backend. yourwebsite.com/administrator/index.php?...iew=manage&search=k2
8 years 7 months ago #2
I have done this but with no luck. My site is still crashed and down. Any other suggestions?
8 years 7 months ago #3
Hmm strange. can you try to re-install k2 and uninstall it again by removing all related k2 extensions in one step?
8 years 7 months ago #4
- Posted by champchoel (27) Offline
Hi Clind,
I've fixed this issue by disabling highlighter module. This module retrieve data from k2 item, that's why this issue occured after you had unistalled the k2.
8 years 7 months ago #6
by champchoel
