Template saber bugs
- Posted by Feroz (2) Offline
We installed subject template at tecs-firensafety.com.sg/test.
The problem we found header is not sticky in all pages when scroll down.shortcode plugin also got problem.. kindly check and advise..thanks
8 years 6 months ago #1
by Feroz
Hi werm,
Sorry for delay in responding.
Have you enabled the sticky header option from the template backend?
8 years 6 months ago #2
- Posted by champchoel (27) Offline
Hi werm,
Please try to go to templates > sabber > tpls > blocks > header.php and on line 39-41, you should see
$navbarbg = 'navbar-bg';
} else {
$affix_header = '';
Please change it into
} else {
$navbarbg = '';
And now you need to create custom.css and add this rule,
.t3-sticky.affix {position: fixed}
Good luck
8 years 6 months ago #4
by champchoel
} else {
$affix_header = '';
} else {
$navbarbg = '';
Good luck
