Mini K2 customization
I've installed Mini K2 Content and I face a problem: It shows only 3 K2 items per row. How can I set it to 4 items per row?
Also, how can I center the module?
Pls advice
Chris
8 years 2 months ago #1 by Chris Vrakotas
Hi cvrak. Really sorry I missed your post. Are you still having problem with that?
Also please let me know the URL of your site so I can take a look
8 years 2 months ago #2 by TemplatePlazza
The center problem was a template issue. I solved.
But remains the problem with the items per row. Now I've set 3 items. If I set 4, the result is 2 rows with 3 and ond item.
How can I set every row to display 4 items?
The URL is www.chrisomelo.com . The module position is just above footer.
8 years 1 month ago #3 by Chris Vrakotas
Can you try to temporarily switch your website template to the default one (protostar) and see whether the issue persist or not. I'd like to see whether this is something related to template issue or something else.
8 years 1 month ago #4 by TemplatePlazza
Sorry for my delayed answer, the problem is still here.
I switched to protostar, but still only 3 K2 items / row.
I added a light gray background and I see that centering is not ok as well
Pls advice
8 years 1 month ago #5 by Chris Vrakotas
Still no solution...
Anybody can help??
8 years 1 month ago #6 by Chris Vrakotas
