Xtypo issues with JCE caption plugin
- Posted by Juan Luis Garcia (1) Offline
I have similar issues as described in this question: www.templateplazza.com/forum/xtypo-confl...gin-using-jce-editor
I solved most of the issues (such as the size of the image with caption on the preview) by removing the span[class] from Extended Elements field in JCE Configuration.
However I still have issue related with image position when applying a JCE Caption and Xtypo is enabled.
If I leave the options as commented, and I apply a caption to an image centering both, I find that Xtypo interferes this and doesn't allow image and caption to be centered on the JCE Editor and Preview (see attached screenshot).
If I disable xtypo plugins this works fine.
Platform details:
Joomla: 3.8.13
PHP: 7.1.22
Xtypo + Button: lastest
JCE Pro: 2.6.33
Seems that the issue is only with the JCE WYSIWYG editor and also with its preview opiton.
May you please help with this?
7 years 11 months ago #1
by Juan Luis Garcia
Platform details:
Joomla: 3.8.13
PHP: 7.1.22
JCE Pro: 2.6.33
Hi juanlux, sorry for delay in responding due to weekend break.
Regarding your problem, I have tried to replicate it in my end but I'm unable to spot the issue. Please have alook on the video below. Did I miss something?
7 years 11 months ago #2
Anyway how did you add an image caption in JCE? I didn't see that option from my JCE. Is it a Pro feature?
7 years 11 months ago #4
