Related items extended not working
- Posted by projger (4) Offline
Hello! Unfortunately the plug-in of Related items extended does not work at my website... I established it, chose a module position, included display on all pages, included a plug-in, but there and did not earn. What settings still need to be made?
7 years 11 months ago #1
by projger
Hi projger,
I'm unable to enter your website because you didn't provide the username.
Anyway, could you tell me on what page you publish the module?
What 'Period of novelty' setting you have on the module parameter?
7 years 11 months ago #2
tolkvosne.ru/vse-sny/sny-o-raznykh-sobytiiakh.html
Advertizing has to be published on this page, in the right sidebar, under advertizing.
Unfortunately I do not know English therefore give I to you I will give a user name, and you posmtrit and please write in what was.
Thanks so much!
7 years 11 months ago #3
by projger
Thanks so much!
Hi projger,
Thanks for the username. I have checked your website and I think the problem is because you are choosing Meta Keyword as the Related Item Based on option
https://www.dropbox.com/s%2F8vfsfkd7rs4pei7%2Ffpqs8.jpg?raw=1
but the fact is, most of your article doesn't have meta keyword
https://www.dropbox.com/s%2Fpievopwhuwqcvwu%2Fqck5m.jpg?raw=1
If you choose Meta Keyword as the Related Item Based on setting then the module will find related item based on their meta keyword similiarity, in this case the module unable to find it.
7 years 11 months ago #4
And if you select the Tags option, then the information will be taken from the text of the article? I set this parameter to the Tags position, but similar materials were not displayed.
7 years 11 months ago #5
by projger
No, if you set the parameter to 'Tags' then the item relation will be taken from Tags similiarity, not from the text of the article
7 years 11 months ago #6
