How to stop text wrapping around formatted headings
I have formatted a text heading using the Xtypo "Rounded 4 Left" format. This works OK but how can I stop the following text (which should be below the formatted heading, from wrapping around the heading and creating a two-column appearance?
7 years 11 months ago #1 by Traveller439
Hi, Could you let me know the URL of your site so I can take a look and understand the problem better?
7 years 11 months ago #2 by TemplatePlazza
Thanks for responding.
A test page can be seen at: 79.170.40.166/jadance.co.uk/index.php/test
Alternatively, go to 79.170.40.166/jadance.co.uk/index.php and you will see a menu item "Test" at the bottom of the menu.
Obviously, if I allow the orange "Rounded 4" styling to go across the page, the text appears below as normal.
PS - this site is under development so lots of things may not work correctly. This also explains the unusual URL.
7 years 11 months ago #3 by Traveller439
"Rounded 4 Left" is indeed designed for that look. It will aligned (float) to left with 50% width. May I know what look you would like to achieve?
7 years 11 months ago #4 by TemplatePlazza
Thanks for the reply. No, if that is the intended format then I understand. I will work with that.
7 years 11 months ago #5 by Traveller439
Ah ok. Anytime;)
7 years 11 months ago #6 by TemplatePlazza
