keep Floating Buttons without click
Please kindly tell me how to keep the Floating Buttons open without a click. I followed the example in the forum but, did not work.
Is there any other workaround?
7 years 11 months ago #1 by Jah Thwaay
Hi, You can do that by editing the file modules/mod_floating_buttons/assets/css/style.min.css
Find class .jfab_btns_wrapper and then delete the property
display: block;
Then find class .jfab_btns_wrapper button and then delete the property
-moz-transform: scale(.1);
    -webkit-transform: scale(.1);
Then find class ..jfab_tooltip button and then delete the property
transform: rotate(410deg);
    -ms-transform: rotate(410deg);
    -webkit-transform: rotate(410deg);
7 years 11 months ago #2 by TemplatePlazza
