Floating Buttons on mobile
- Posted by ZI.SH (5) Offline
Hello all,
From some reason the button does not show on my mobile.
site: kav-yashar.com
template: Hellix3
Thanks a lot for your help
7 years 11 months ago #1
by ZI.SH
template: Hellix3
Hi, I see that you have an jquery error on your website, maybe that is the cause of the problem
https://www.dropbox.com/s%2Fb0x9nhbew89ogxe%2Fwowz3.jpg?raw=1
To debug it, you can start disabling Joomla extensions one by one, until the error disappears
7 years 11 months ago #2
Thanks for your quick answer.
Actually I am not such an expert, and do not know how to display this error.
One more comment on that issue: the button does appear on other pages. Only on the home page the button is not displayed.
7 years 11 months ago #3
by ZI.SH
Hello again,
I searched and found that the "Vinaora Nivo Slider" module interfere with the floating button module. After updating "Vinaora Nivo Slider" by changing the value for "Jquery Source" from "Local" to "None" - the problem is solved.
Not sure what will go wrong in the future with these images, but currently the "Vinaora Nivo Slider" images are displayed as usual.
7 years 11 months ago #4
by ZI.SH
