MiniK2 alignment problem
- Posted by Oliver Johnson (4) Offline
I've just installed MiniK2 and set it to newsticker and it all works fine. However the alignment is wrong.
The Headline background is cut off at the bottom as is the headline text itself and there appears to be too much space above.
I've tried increasing the height under Newsticker Sub Template Parameters but whilst that adds more height to the module the alignment is still wrong and cut off.
7 years 10 months ago #1
by Oliver Johnson
Hi, Try to add this lines of code your css file :
7 years 10 months ago #2
#tp-tickerwrp .ticker-title {
line-height:105%!important;
width:80px!important;
#tp-tickerwrp .ticker-content{
line-height:100%!important;
padding-top:5px!important;
display:block;
margin-left:5px;
Thank you for the quick response. I tried adding this to template.css and also to a custom.css but unfortunately neither made any difference.
7 years 10 months ago #3
by Oliver Johnson
I didn't see that codes in the www.worthingarcheryclub.co.uk/templates/...ss/custom/custom.css
www.worthingarcheryclub.co.uk/templates/...pro/css/template.css
or
www.worthingarcheryclub.co.uk/templates/...ine/css/template.css
Are you sure you have added it?
7 years 10 months ago #4
or
Sorry, I did add it but had removed it as it wasn't doing anything. I had however forgotten about adding it to the magazine template. I've added it now and it is a bit better, thank you.
However the text of the headline doesn't align to the middle of the Headlines button and still loosing the tail of letters like y,g,p etc. Also is it possible to reduce the space above the button as it's too large?
7 years 10 months ago #5
by Oliver Johnson
Fixed it now. Thanks for the code, very much appreciated.
7 years 10 months ago #6
by Oliver Johnson
