Simple Floating Buttons and EasyDiscuss conflict
- Posted by Giuseppe (4) Offline
Hi.
I'm using EasyDiscuss in one of platforms that I'm building. I also want to use Simple Floating Buttons but I found that it's conflicting with the notifications module of EasyDiscuss.
I also have jQueryEasy installed.
Can you help me to solve this issue? Thanks a lot in advance!
7 years 10 months ago #1
by Giuseppe
Just a mistake: in my post I've written "Mobile Optimizer Menu" instead of "Simple Floating Buttons". That's another extension that I've tested. Sorry!
7 years 10 months ago #2
by Giuseppe
Hi, Can you try to add this line :to the file https://t***mo.it/modules/mod_floating_buttons/assets/js/script.min.js
at the top of file, just before the code
7 years 10 months ago #3
jQuery.noConflict();at the top of file, just before the code
(function(t){t.jfab||(t.jfab=new Object)Please Log in or Create an account to join the conversation.
Thank you for your quick answer!
I tried as you suggested but with no results about the issue.
I also tried with jQuery Easy enabled and disabled...
7 years 10 months ago #4
by Giuseppe
Hi.
I want to inform you that I've solved this issue!
I just disabled a setting in EasyDiscuss (you can see it in attached screenshot).
Hope it will be useful for you.
7 years 9 months ago #5
by Giuseppe
