Floating buttons target _blank
- Posted by aptel (2) Offline
I'm trying to open the button url to a new window, but I don't know where to look to add in the html "target=_blank",
Paul
7 years 8 months ago #1
by aptel
Paul
Hi, sorry for delay in responding.
For that, you need to edit the file : ../modules/mod_floating_buttons/tmpl/default.php
at lines 26 you will see this code:change that to :
7 years 8 months ago #2
"icon":"<?php echo $item->child_item_icon; ?>""icon":"<?php echo $item->child_item_icon; ?>",
"target":"_blank"Please Log in or Create an account to join the conversation.
So, now all the links I have can be opened in a new window.
But in the floating buttons module I have internal links and external links. I would like that my external links are opened in a new window and my internal links in the same window..
7 years 8 months ago #3
by aptel
Ah I see. Then you will need some custom modifications for that purpose.
7 years 8 months ago #4
- Posted by NicolasJ (3) Offline
Same question, i have internal and external links.
Dispite the fact that your extension is free and answered nicely to my needs, it really miss the target option.
Do you intend to add that or do we have to manage it ?
Thanks a lot for your work and your answers !
Nicolas
5 years 11 months ago #5
by NicolasJ
Nicolas
Hi Nicolas, yes you will need some custom modifications for that purpose
5 years 11 months ago #6
