Menu 2 Panel and PHP 7.3.2
- Posted by milak (1) Offline
Hello, with php 7.3.2 there is an error: Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /.../modules/mod_menu2panel/helper.php on line 85
Do you have any updates or help. Thank you very much
7 years 7 months ago #1
by milak
Hi Milak, Sorry for the delay in responding, I missed your post
I'll check this now and will back to you very soon
7 years 7 months ago #2
Hi, Thanks for waiting. It took me some time to install php 7.3.2 to my dev environtment.
Anyway, I'm unable to replicate your issue. The module is working fine in joomla 3.9.3 and no error message popped out at my end.
Could you let me know the URL of your site so I can take a look? Also can you let me know your module paramters settings so I can try to replicate the problem?
7 years 7 months ago #3
