Module in modal !
I just bought this extension but I do not know how to insert modules like the newsletter module that I have in my homepage! from what I understood it is necessary that I insert the source code of this module through the editor. but here I am not an encoder! Is there a simple way to get this code ?
7 years 4 months ago #1 by alaabouch
Hi zoohyr,
You don't need to insert the source code.
You just need to set the Content Source then set the Module Position to the position where the newsletter module is published.
The file comes with a documentation file. Please make sure you read that too ;)
7 years 4 months ago #2 by TemplatePlazza
Hello and thank you for your answer,
the module was displayed correctly. but I would like to have a service from you. can you spin me the source code of the newletter field show in your demo. because I can not display correctly the acymailling newsletter module and I would like to integrate it via the editor of the module !
7 years 3 months ago #3 by alaabouch
Hi, You just need to publish the acymailing newsletter module in a position and then load that position from the module in modal parameters page. Have you tried that?
7 years 3 months ago #4 by TemplatePlazza
Additionally, could you let me know the URL of your site? so I can have a look what you have done so far
7 years 3 months ago #5 by TemplatePlazza
actually it worked but I did not like the background as well as the location of the field in the window ! here is the link of the site : www.aidepharmacien.ma
to see my example homepage in french !
here I activate the module to see it. thank you so much
7 years 3 months ago #6 by alaabouch
