Mini frontpage tittles
- Posted by jordi (7) Offline
Hi, i'm ussying mini frontpage in my home page, and i want to change the tittles of the articles to h1, because i want work in the seo of the page. I see the css of the theme i use in the mini frontpage module, but i don't see the solution.
Can you help me??
Thank's.
13 years 9 months ago #1
by jordi
Can you help me??
Thank's.
- Posted by ronysyz (191) Offline
you can try by your self with these tricks:
1. Check your "Layout Type" (in your parameters), for example: you use "tabbed-fade-in-out"
2. Check your "Other Articles Placement" (in your parameters), for example: you use "Bottom"
so you just need to open: mod_minifrontpage/themes/tabbed-fade-in-out/tmpl/bottom.php
and try to find
for this file, you will see at line 52-54
then change it become to
or you can remove "span"
I hope this trick will help you
13 years 9 months ago #3
by ronysyz
and try to find
if (!empty($show_title)) {
echo modMiniFrontPageHelper::showTagFP( $item->title, $item->link, true, $title_link, '<span class="mfp-introtitle">', '</span><br/>' );
}for this file, you will see at line 52-54
echo modMiniFrontPageHelper::showTagFP( $item->title, $item->link, true, $title_link, '<span class="mfp-introtitle"><h1>', '</h1></span><br/>' );
}or you can remove "span"
echo modMiniFrontPageHelper::showTagFP( $item->title, $item->link, true, $title_link, '<h1>', '</h1><br/>' );
}I hope this trick will help you
