Floatings buttons smooth scroll
- Posted by Ton van der Helm (67) Offline
on my clients testwebsite studiovandergoesslapen.nl/nieuwe-site/ I'm using the Floating Buttons extension. It looks very nice. What I'm trying to achieve is that the (pop-up) button "Omhoog" with the house-icon goes to the top of the page. Since I'm using a Yootheme Pro template I like to use the Smooth Scroll functionality of it.
Is this possible in any way?
Thanks!
6 years 11 months ago #1
by Ton van der Helm
Thanks!
Hi, I believe it's possible but you will you need to modify the module's codebase for that
6 years 11 months ago #2
Oké, this is not one of my specialities
What is the option if I ask you to do this?
Thanks!
6 years 11 months ago #3
by Ton van der Helm
Thanks!
Hi MoI4, I have take a look at the code and it looks like it will be possible by modifying the javascript library. I will try to find the solution for $35 and I will refund it if I'm not successful. If you're interested please contact me using www.templateplazza.com/contact-us. Thanks
6 years 11 months ago #4
Last year november you've made changes to the javascript library of the Floating Buttons extension.
Right now there is an update to install.
But does this overwrite the changes you've made to the javascript library?
Thanks!
Greetings,
Ton
6 years 1 month ago #5
by Ton van der Helm
Thanks!
Greetings,
Ton
Hi Ton, Yes, I have included the smooth scroll update with the latest update so that smoth scroll should be working fine with the latest version. I have also added css adjustment tab in the floating button so now you an add css code to modify the appearance of the module quickly.
But please backup the previous module you have first, before installing the new version.
Andy
6 years 1 month ago #6
Andy
