WhatsApp Multi Agent - translate text
Where can I change the text below in my own language?
"Sorry but we're offline at the moment. Please fill out the form below and we will get back to you as soon as possible."
6 years 9 months ago #1 by Harryb
Hi You can add language overrides. Please have a look on this screencast
6 years 9 months ago #2 by TemplatePlazza
Thanks it didn't work that way. I had to change the names manually via ftp in the override file. Now everything has changed
6 years 9 months ago #3 by Harryb
Hmm strange it should be working good.
It's ok too. But if you are willing to touch the physical files, I'd suggest you to add new language files instead of making an override, so everytime new update is available it won't break the changes you have made.
To add new language file, simply copy these files :
/language/en-GB/en-GB.mod_whatsapp_agent.ini
/language/en-GB/en-GB.mod_whatsapp_agent.sys.ini
to
/language/xx-XX/xx-XX.mod_whatsapp_agent.ini
/language/XX-XX/xx-XX.mod_whatsapp_agent.sys.ini
and then translate them.
*xx-XX is your country code
6 years 9 months ago #4 by TemplatePlazza
