Xtypo - stripped tags in front-end editor
I'm using Joomla 2.56 , when I login from the front-panel I cannot see the tags whereas they are displayed in the admin panel > article editor. I tried with JCE & TinyMCE and I've disabled HTML filtering and other settings from both.
logging in the front as Publisher & SuperAdmin has the same effect.
any clue ?
thank you
13 years 1 month ago #1 by alex
  • Posted by TemplatePlazza (5420) Offline
Hi Alex,
Did you mean, you were unable to add xtypo tags just like {xtypo_code}this is code {/xtypo_code} in the frontend editor?
13 years 1 month ago #2 by TemplatePlazza
I'm able to add the tags {xtypo_code} but , once the article is saved and opened again, I'm NOT able to see them again. They are visibile only in the back-end admin > editor, not in the front-end editor anymore..
13 years 1 month ago #3 by alex
I have rechecked and can't reproduce the problem at my end.
see video in here : d.pr/v/CxkE
It's probably something related to your joomla installation. Please try with other joomla tags such us {loadposition position-12}
13 years 1 month ago #4 by TemplatePlazza
