minifronpage thumbnails problem
- Posted by niels (2) Offline
the automated generated thumbnails are working great, but is it possible to change how the thumbnails are generated ?
if faces of heads are in top area of picture they are cut as the generated image uses the center of the image,... hope you understand the issue. would be a charm if this is an option to change how thumbnails are generated. i would buy the extension if this would motivate you to add it
6 years 8 months ago #1
by niels
Hi niels, we will add two additional methods to the thumbnail creation type for Minifronpage pro : resize and crop.
'Resize' will basically preserve the original image ratio and 'Crop' will allow you to crop the img from the top left
6 years 8 months ago #2
great, as promised i bought your extension
thank you very much for your efforts
6 years 8 months ago #3
by niels
Hi niels, Thanks!
Hopefully the update will be released very soon this week
6 years 8 months ago #4
Hi Niels, We have updated the module with the more advance thumbnail settings. Please have a try
6 years 7 months ago #5
