New Features on Simple Floating Buttons
Hello about Simple Floating Buttons,
could you please insert option of windows target link and position on the screen?
6 years 8 months ago #1 by Santo
Please edit this file : ../modules/mod_floating_buttons/tmpl/default.php
at lines 26 you will see this code:
"icon":"<?php echo $item->child_item_icon; ?>"
change that to :
"icon":"<?php echo $item->child_item_icon; ?>",
                "target":"_blank"
6 years 8 months ago #2 by TemplatePlazza
Thank's you so much, last question if I would like to put it just in some of them, how can I do that?
6 years 8 months ago #3 by Santo
Hmm that will need some code modifications on php and also xml file.
6 years 8 months ago #4 by TemplatePlazza
