Whatsapp plugin doesn't work as I want
I bought the whatsapp multi agent from you a week ago. It doesn't work as my want. I want to whatsapp open for 24 hours.but it is seen only sending mail utility after one hour:( I also want it must connecting to whatsapp directly when someone has clicked to whatsapp icon.
6 years 7 months ago #1 by ayhan
Are you sure you have set the Repetition Rule,Starting Online,End Online for the agent correctly?
https://www.dropbox.com/s%2Foxkqaxr9py9fcrh%2Fwag.jpg?raw=1
It doesn't work like that. It will connect to whatsapp after user type the message on the message box and click send button/press enter. I'm assuming you have already tested the demo site before purchasing, right?
6 years 7 months ago #2 by TemplatePlazza
