Mini FrontPage - missing letters
I found this module and it's great... but there's small problem.
It removed some letters - first letters withing <strong> tag although number of characters missing isn't constant.
Examples:
instrumentów <strong>KETRON AUDYA</strong>.
on MFP looked like this: instrumentów UDYA.
powinien posiadać już <strong>system w wersji 4.1B lub wyżej</strong>
on MFP looked like this: powinien posiadać już tem w wersji 4.1B lub wyżej
Anybody knows what can cause that?
13 years 9 months ago #1 by Tobiasz Kiszlo
Hello Toobkin,
It's strange, because i have tried to copy your normal article and tested it. I get your texts working good.
I use the default template from Joomla and the default editor too
Can you give me more information what you have done?
13 years 9 months ago #2 by ronysyz
Actually I wasn't changing anything, got Joomla 2.5.8 with olwebdesign template "ol_aspita" with modified only graphic files.
I have moved this site from other server and I admit I didn't pay enough attention for such details so I don't know if the same happened before - but I guess it doesn't matter much (everything works fine, there's only this one glitch).
What else could help in figuring out what's going on? Would attaching some files from my server help you in any way? Just say what can be useful and you got it. ;)
I spent whole day searching for an alternative and I have to say there's nothing that would be even close to Mini FrontPage. I would really appreciate your help.
13 years 9 months ago #3 by Tobiasz Kiszlo
What about if you try to change your template become to the default template from Joomla and let we see what happen
13 years 9 months ago #4 by ronysyz
Tried with beez20 and atomic - no change.
I guess the only thing now I can do is to start from scratch and see if situation happens again...
What do you think?
13 years 9 months ago #5 by Tobiasz Kiszlo
can i get your super administrator account?
so i can try by my self?
13 years 9 months ago #6 by ronysyz
