Minifrontpage has problems with Internet explorer
Hi, i have Minifrontpagepro and I want to use the carousel big, in all browsers it works well, but in internet explorer it doesn't work.
I've reviewed the demo and it doesn't work either in internet explorer.
can you help me with this?
6 years 7 months ago #1 by luz quintero
Hi, I've checked the demo with Internet Explorer and it does work fine.
https://www.dropbox.com/s%2Fnfthyphpoas20b4%2Fminifrontpagepro.jpg?raw=1
Can you tell me what Internet Explorer and what windows version do you use?
6 years 7 months ago #2 by TemplatePlazza
Hi. I have Windows 10. The image is Edge Microsoft, but I mean IE11
In others browsers it works, I don't know if this browser is important or could affect the traffic to my page. Could you advise me about this?
6 years 7 months ago #3 by luz quintero
Hallo, the free carousel demo 3 and demo 4 don't show the thumbnail in IE 11 (Edge).
Have you a solution for this problem?
6 years 7 months ago #4 by Reinhardt
Hello guys,
IE 11 is the old browser from Microsoft. Most developers suggest people to abandon IE11 because it has so many modern css support limitations and also latest javascript adoption support such as ES6. Microsoft already dropped its support for IE 7 for windows 7 (but likely will continue to support it in Win 10) and encourage its user to use Edge browser. The global IE11 usage right now is 3% but it seems that the biggest contributor is the use of win7 in corporates (win7 itself already reached its end of life at Jan 2020).
I will try to find solution for this and back to you guys soon.
6 years 7 months ago #5 by TemplatePlazza
I imagined it. Don't worry, I think IE11 is about to go extinct and the minifrontpage extension is very good. It is an unimportant aspect, but I wanted to know your opinion.
It has helped me a lot.
Best regards and thank you.
6 years 6 months ago #6 by luz quintero
