Simple Floating Button not wiorking
Hello team,
I just installed and confiure Simple Floating Button but it is not working it is not displayed anywere in the website.
My site is www.doitliketakemoney.gr
My wish is to add a module to that button. How to configure that?
Thank you in advance
6 years 7 months ago #1 by dhatzi
Hi, it looks like the module isn't published in the correct module position. I tried to publish it in 'debug' position but it's still not displayed. Please check what position is available on your template
6 years 7 months ago #2 by TemplatePlazza
Hello again,
in some pages it is displayed, maybe some other module blocks yours. Look at the menu Store Menu->Coupons it is displayed
6 years 7 months ago #3 by dhatzi
is it possible to move it to the other side of the scrren?
6 years 7 months ago #4 by dhatzi
Hmm it looks like it's a jquery ordering/conflict issue. See this
https://www.dropbox.com/s%2Fhyox455d3wp840r%2F41ibx.jpg?raw=1
You can try to install this extension to solve jquery related issue: extensions.joomla.org/extension/jquery-easy/
6 years 7 months ago #5 by TemplatePlazza
Installing that extension it would fix this issue?
6 years 7 months ago #6 by dhatzi
