Responsive Banner Slide timing??
I just bought the extension and I can't get the timing options to work. It just continues to change every second or so.. I've tried changing the interval and/or speed to low numbers and high numbers alike and it does NOTHING! ABSOLUTELY NOTHING.
No point having a fancy banner carousel if no-one can read the text. No?
Help please??!??
see www.ymt.com.au to see what I mean by the rotation. Thanks.
13 years 9 months ago #1 by Pete
Hi sempytender, thank you for your recent purchase.
Every time you change the backend parameters and the change doesn't work please try to clear your browser cache first.
Btw, I have visited your website and found that the animation timing between banners is already a quite long. Is the problem already resolved?
13 years 9 months ago #2 by TemplatePlazza
I too am having a timing issue with Responsive Banner Slider. I have cleared both my browser cache and Joomla's cache, but no matter what I put into the Interval or Speed settings, each banner is only visible for roughly 3 seconds before changing. The animation speed is fine, but the banner needs to display a little longer.
My settings are currently at 10000 for Slide Interval and 1000 for Slide Speed. You can see my other settings in the attached screen capture. I would provide a URL, but the site is currently set to Offline while I resolve this and other minor problems before launching the site, which I hope to do VERY SOON. :)
I've also just noticed that despite having Show Navigation set to No, the little circle-arrow next and previous images DO appear on the banner when you mouse-over. Is that normal? I'm fine with them appearing, but I mention it as it might be a clue to the more pressing timing issue.
I can provide administrator access to you via PM or e-mail, but I cannot find a way to PM you via this forum? I hope you can help me soon. This is a time-sensitive problem.
Thank you for your speedy response.
13 years 9 months ago #3 by Matt
Hi guys, we have uploaded the new Responsive banner 2.2.1 with additional Autoplay delay option for sequence effect. Please try
13 years 9 months ago #4 by andy
